ProtoTRAK MX2 CNC
Versión: 6.10
TRAK TRM
ProtoTRAK MX2 Retrofit
Note – For the MX2 system disk, you must use tape up the square hole that is located in the corner of the floppy before proceeding.  The MX2 used double density floppy drives (720k), and the high density floppy will not work on this drive unless using this trick.
Download ProtoTRAK MX2 CNC software here
mx2_61.exe 446 KB
