ProtoTRAK RX CNC Software (RMX, RLX)
Versión: 3.1.2
Machining Centers
TRAK VMC2
TRAK TMC5
TRAK TMC7
TRAK TMC10
TRAK TMC12
TRAK TMC14
Turning Centers
TRAK TC2
TRAK DPM RX2
TRAK DPM RX3
TRAK DPM RX5
TRAK DPM RX7
TRAK TRL 1630RX
TRAK TRL 1630HS-RX
TRAK TRL 1845RX
TRAK TRL 2470RX
TRAK TRL 3060RX
TRAK TRL 30120RX
ProtoTRAK RMX2 Retrofit
ProtoTRAK Upgrades
MX Series to RMX Upgrade
M Series to RMX Upgrade
AGE Series to RMX Upgrade
EDGE Series to RMX Upgrade
EMX to RMX Upgrade
SM to RMX Upgrade
SMX to RMX Upgrade
KMX to RMX Upgrade
Notable bug fixes
  • Fixed issue with previous download where versions older than 2.5.4 would give a CRC Checksum Error.
  • Fixed issue on RLX when after opening a DXF file, the run panel led’s would stop working properly and software could crash.
  • Fixed green message prompts not appearing correctly when attempting to add a tool on TMC or VMC2 machines.
  • Fixed issue where Tool Table screen would flicker when spindle is turned on and tool sorting is used.
  • Fixed issue with MPF converter not showing up correctly
Instructions for updating RMX & RLX Pendants
  1. Disable your anti-virus software before downloading. (Some anti-virus software may silently omit necessary files, and cause your machine to have unexpected symptoms.)
  2. Be sure to delete any previous PT10-SETUP folder from your USB flash drive first.
  3. Download the RX_x.x.x.zip file to your computer.
  4. Open the newly downloaded zip file to reveal the PT10-Setup folder.
  5. Unzip/extract the folder (or drag and drop it) from the zip screen to your USB drive.
  6. Navigate to your USB flash drive, and open the PT10-SETUP folder.
  7. Double click on ValidateFiles.exe
    This will run a quick CRC check to ensure that the download is complete and not corrupt. You should get a confirmation that looks like this:
    CRC Check Confirmation - ProtoTRAK RX CNC Software
    In the event that any of them failed, please retry the steps, making sure to disable your antivirus and deleting any previous instance of PT10-SETUP folder from your USB before proceeding.
  8. Take your USB flash drive and plug it into your ProtoTRAK RMX / RLX control.
  9. Go to SETUP, SERV CODES and then enter code 316, and press ABS SET.
  10. Highlight the drive letter corresponding to your USB flash drive, and then press YES twice to initiate the software update.
