TRAK Bed Mills featuring the ProtoTRAK RMX CNC
The Best Machines Ever Made for Toolroom and Short Run Production.
  • Manual with DRO, 2 or 3 axis CNC
  • Real handwheels so you can work manually
TRAK Bed Mills
VIDEO: TRAK RX Series Bed Mills Overview feat. the DPM RX3
Watch the TRAK Bed Mills Overview Video
TRAKing Pat explains the features and options of the RX series toolroom mills.
Key Features of TRAK Toolroom Bed Mills:
Maximize Productivity and Efficiency
  • Manual, 2 or 3 axis CNC
  • CNC always available
  • ProtoTRAK RMX CNC integrated at the factory
  • TRAKing® — control of program run
  • Programmable spindle control
  • Real handwheels for manual operation and TRAKing®
  • DRO Mode with power feed, teach and more!
  • Head swivels right and left
  • Low and high gear range
Unmatched Flexibility and Precision
  • Ballscrews in the table, saddle and column
  • Brushless servo motors with .000003" encoder resolution
  • Quill scale and column ballscrew encoder integrated into one Z dimension
  • Turcite coating on bearing surfaces to reduce friction
  • Wide saddle, box ways
  • Bed support of table and saddle
  • Entire ram moves along the column for rigidity
Models
TRAK DPM RX2 Bed Mill Three Quarter View
  • Table Size: 49″ x 9″
  • Travels: 31.75″ x 16″ x 23.25″
  • Spindle Motor: 3 HP Continuous
  • Spindle Taper: R8
TRAK DPM RX3 Bed Mill Three Quarter View
  • Table Size: 50″ x 10″
  • Travels: 31.5″ x 17″ x 25.81″
  • Spindle Motor: 5 HP Continuous
  • Spindle Taper: 40 Taper
TRAK DPM RX5 Bed Mill Three Quarter View
  • Table Size: 50″ x 12″
  • Travels: 40″ x 20″ x 25.81″
TRAK DPM RX7 Bed Mill Three Quarter View
  • Table Size: 76″ x 14″
  • Travels: 60″ x 23″ x 24.25″
  • Spindle Motor: 7.5 HP Continuous
