ProtoTRAK RLX CNC - Touchscreen
as only ProtoTRAK could do it
Flyout Windows
Tap on an Info Key and a Flyout Window appears. Tap it again and you're back on the screen you started.
Just tap TOOL TABLE to define your tools as you program.
ProtoTRAK RLX CNC Flyout Window for the Tool Table
Enhanced ProtoTRAK Assistance in a Flyout Window gives you the help you need on demand.
ProtoTRAK RLX CNC Flyout Window For Enhanced ProtoTRAK Assistance
There's more to Fly Out Windows!
  • Status to check program names, in/mm conversion and more
  • Math Help with 21 separate routines to calculate print dimensions.
  • Options for quick access to advanced functions
  • Defaults that customize the ProtoTRAK to your machining style
  • Keyboard for letters, numbers and symbols
  • Calculator for simple math with auto load of data
Powerful And Unparalleled Convenience At Your Fingertips.
Swipe to Navigate, Tap to Enter
Simple changes to the program have never been easier. Move easily through your program by swiping as the line drawing shows you which event you are viewing.
Tap to select the data you want to input or change.
RLX CNC Touchscreen - Tap to Enter
Interact with Your Parts Graphics
You can zoom, pan or rotate your drawings and 3D models by using gestures on the touchscreen to see different angles.
ProtoTRAK RLX CNC Touchscreen Gestures
