Use different elements and the SINUMERIK ONE runs them as a single program. The diverse formats such as those shown below are processed by the SINUMERIK ONE for you, eliminating the need for you to convert everything into the same format.
The powerful Contour Editor works within the all the programming methods of the SINUMERIK ONE. Use graphical elements to create even complex shapes. Automatically calculates intersections and points of tangency.
Also use Contour Editor to work with features in DXF files. Open the drawing data within the Contour Editor, then use define tool path and even edit the geometry.
Program more efficiently and with better results owing to the true representations of part and tool geometry. Simulate your part program with high fidelity including controls for program speed, single block operation and stop/start.
Calculations for machining time will help you see the effect of different strategies. You can even run simulations of different programs as a job is being run.
Open DXF files on the SINUMERIK ONE to easily transfer data into your program. Program faster and reduce errors on programming dimensions.
Open and use elements of multiple DXF files in the same program.
Works within all the programming methods. Easily command specific features from drawing elements. Set your own part reference independent of the drawing origin.
