TRL 1845RX Toolroom Lathe
Generous capacities and excellent performance over its entire range of motion
  • Swing Over Bed: 18″
  • Distance Between Centers: 45″
  • Spindle Through Hole: 2.36″
  • Spindle Speed Range RPM: 80 - 850, 250 - 2,500
Standard Features
  • ProtoTRAK RLX CNC integrated into the machine at the factory
  • Constant Surface Speed (CSS) Programming
  • Inch Per Revolution (IPR) Programming
  • Optional turret for automatic tool changes
Specifications All Machines
  1440EX 1630RX 1630HS-RX 1845RX 2470RX 3060RX 30120RX
ProtoTRAK CNC Model
ELX RLX RLX RLX RLX RLX RLX
Height of Centers 7″ 8″ 8″ 9″ 12″ 16.5″ 16.5″
Distance between centers 40″ 30″ 30″ 45″ 70″ 60″ 118″
Swing over bed 14″ 16″ 16″ 18.1″ 24″ 33″ 33″
Swing Over Saddle Wings 14″ 16″ 16″ 17″ 24″ 33″ 33″
Length of Gap N/A N/A N/A N/A N/A 15.5″ 15.5″
Swing Over Gap N/A N/A N/A N/A N/A 43.5″ 43.5″
Swing Over Cross Slide 7″ 8.6″ 8.6″ 9.13″ 14.5″ 21.2″ 21.2″
Maximum Turning Length (Z Axis Travel) N/A N/A N/A N/A N/A 60″ 121″
Cross Slide Travel 8″ 8.5″ 8.5″ 10.6″ 12.5″ 20.5″ 20.5″
Tool Section Max 3/4″ 3/4″ 3/4″ 1″ 1″ 1.5″ 1.5″
Coolant Reservoir Capacity 3 gal 8 gal 8 gal 13 gal 15 gal 35.6 gal 48 gal
Oil Pump - Way Lubrication N/A 2 litros 2 litros 2 litros 2 litros 2 litros 2 litros
Head Stock Lubrication - Type N/A 1.5 gal 1.5 gal 1.85 gal 5.3 gal
6.3 gal w/oil cooler option
N/A 8.5 gal
Rapid Speeds 100 IPM on Z Axis
100 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
400 IPM on Z Axis
200 IPM on X Axis
Bed
Width Of Bed 8.1″ 12.6″ 12.6″ 13.4″ 14.57″ 18″ 19.69″
Height Of Bed 10.6″ 12.6″ 12.6″ 12.4″ 15″ 15.75″ 18.7″
Spindle Nose D1-4 D1-6 A2-4 D1-6 D1-8 A2-11 A2-11
Spindle Through Hole 1.56″ 2.12″ 1.57″ 2.36″ 4.09″ 6.30″ 6.30″
Spindle Taper MT#5 MT#6 MT#5 MT#6 MT#8 Non MT taper Non MT taper
Taper In Reduction Sleeve 3 N/A N/A MT#4 MT#5 MT#5 MT#5
Spindle Dia At Front Bearing 2.36″ 3.15″ 2.56″ 3.35″ 5.51″ 7.87″ 7.87″
Number Of Bearings 2 2 5 2 2 2 2
Number of Speeds or Ranges 12 1 1 2 2 2 2
Spindle Speed Range RPM 60 - 2,400 150 - 2,500 150 - 4,000 80 - 850, 250 - 2,500 40 - 670, 100 - 1,800 20 - 415, 40 - 1,300 20 - 415, 40 - 1,300
Spindle ID Thread (end of spindle) N/A M56 x 2MM Pitch M56 x 2MM Pitch N/A N/A N/A N/A
Quill Travel 5″ 5.75″ 5.75″ 6″ 8.5″ 8″ 8″
Quill Diameter 1.575″ 2.36″ 2.36″ 2.56″ 3.5″ 4.13″ 4.13″
Quill Taper Hole MT#3 MT#4 MT#4 MT#4 MT#5 MT#6 MT#6
Spindle Motor
Horsepower 5 HP 7.5 HP 7.5 HP 10 HP 15 HP 30 HP 30 HP
Power Requirements - Machine
Voltage Control: 110V
Machine: 200V - 240V
200V to 240V 200V to 240V 200V to 240V 200V to 240V 480V +/- 10%
(432V to 528V)
480V +/- 10%
(432V to 528V)
Amps Full Load Current Control: 8A
Machine: 15A
44A 44A 54A 73A 62A 62A
Phase/Hz Control: 1/60
Machine: 3/60
3/60 3/60 3/60 3/60 3/60 3/60
Net (L x W x H), lbs. 73″ x 44″ x 57″
1,800 lbs
82″ x 45″ x 72″
2,750 lbs
82″ x 45″ x 72″
2,750 lbs
88″ x 55″ x 70″
3,285 lbs
129″ x 84″ x 79″
6,500 lbs
150.31″ x 86.61″ x 88.25″
13,970 lbs
212.6″ x 86.61″ x 88.25″
18,920 lbs
Shipping (L x W x H), lbs. 78″ x 49″ x 67″
2,200 lbs
87″ x 45″ x 70″
3,420 lbs
87″ x 45″ x 70″
3,500 lbs
91″ x 52″ x 79″
3,800 lbs
134″ x 65″ x 79″
7,500 lbs
162″ x 90.55″ x 96.25″
17,500 lbs
222.44″ x 90.55″ x 96.25″
21,000 lbs
Coolant Pump Motor HP* 1/8 HP 1/8 HP 1/8 HP 1/8 HP 1/8 HP 1/4 HP 1/4 HP
Spindle Motor Brake Magnetic Dynamic Dynamic Dynamic Dynamic Dynamic Dynamic
Way Surface Hardness 400-450 HB 400-450 HB 400-450 HB 480-560 HB 480-560 HB 480-560 HB 480-560 HB
Head Stock Lubrication - Type Splash Lube Oil Bath Grease Oil Bath Oil Bath Oil Bath Oil Bath
Tooling Kit 3/4″ 3/4″ 3/4″ 3/4″ or 1″ 1″ 1-1/4″ 1-1/4″
Chuck 6″, D1-4 8″, D1-6 6″, A2-4 8″, D1-6 12″, D1-8 20″, A2-11 20″, A2-11
5C Collet Closer D1-4 D1-6 A2-4 D1-6 N/A N/A N/A
Turret Option N/A 3/4″, 8 Position
1″, 8 Position 1″, 8 Position
* Coolant pumps are optional equipment.
Coolant Pump
Coolant Pump
Coolant pump may be configured to operate as commanded by the Accessory Key on the ProtoTRAK RLX front panel.
LED Work Lamps
LED Work Lamps
For RX series lathes: one tube-style lamp mounted to the underside of the chip enclosure, and one swing arm lamp mounted on top of lathe.
Buck<sup>®</sup> Chuck
1630RX 8″ / D1-6 2.36″
1630HS-RX 6″ / A2-4 1.77″
1845RX 8″ / D1-6 2.36″
2470RX 12″ / D1-8 4.16″
3060RX 20″ / A2-11 7.48″
30120RX 20″ / A2-11 7.48″
8 Station Turret
8 Station Turret
TRAK CNC turrets are designed, engineered and manufactured at our corporate headquarters in Southern California.
1630RX 3/4″
1630HS-RX 3/4″
1845RX 3/4″ or 1″
2470RX 1″
Coolant supplied at each tool. Not available for the 1440EX or 30120RX.
VIDEO: TRAK® Turrets Overview
4 Station Turret
4 Station Turret
1630RX 3/4″
1630HS-RX 3/4″
1845RX 3/4″ or 1″
2470RX 1″
NOW AVAILABLE: Optional boring bar/drill holder kits are available for the 4 station turret for either 3/4″ or 1″ tooling.
The 4-station turret is not available for the 1440EX or 30120RX.
VIDEO: 4 Station Turret Inspection
Dorian® tooling kits make tool changes quick and easy. Repeatable to .001″. The kits include:
  • (1) Quick change tool post
  • (4) Square tool holders for turning, facing and boring
  • (1) Boring tool holder (1″ holder for the 3/4″ kit, 1.25″ holder for the 1″ kit)
  • (1) Morse taper holder (MT4)
  • (1) T-slot nut
1630RX 3/4″
1630HS-RX 3/4″
1845RX 3/4″ or 1″
2470RX 1″
30120RX 1-1/4″
5C Collet Closer
5C Collet Closer
5C Collet Closer with extended taper mount nosepiece.
Not available for 2470RX or 30120RX.
1630RX 14″
1630HS-RX 14″
1845RX 14″
2470RX 20″
3060RX 30″
30120RX 30″
Lathe Diameter Type
1440EX 1.97″ Solid Brass Nib
1630RX 5″ Solid Brass Nib
1630HS-RX 5″ Solid Brass Nib
1845RX 3.94″ Solid Brass Nib
2470RX 6.5″ Solid Brass Nib
3060RX 0.79 - 7.87″ Solid Brass Nib
30120RX 0.79 - 7.87″ Solid Brass Nib
Steady Rest
Steady Rest
Lathe Diameter Type
1440EX .20 to 2.36″ Roller
1630RX .500 to 5.5″ Roller
1630HS-RX .500 to 5.5″ Roller
1845RX 0.4 to 7.87″ Roller
2470RX 1.5 to 8″ Roller
Switches and brackets are set for maximum travel limits. Tripping the switch will cause the servo motors to shut down.
TRAK<sup>®</sup> USB Memory
TRAK® USB Memory
VIDEO: TRAK® USB Memory Option Overview
Extended Warranty
Extended Warranty
TRAK offers a 2 year extended warranty for this product.
TRAKing<sup>®</sup> for RX Lathes
TRAKing® for RX Lathes
TRAKing of programs during program run, GO TO Dimension in DRO Mode.
VIDEO: TRAKing® Option Overview
CAM File Out Converter
Write, save and then run programs with RX Canned Cycle Events on Legacy ProtoTRAK controls in either .CAM Events or .GCD format.
Auxiliary Output
Auxiliary Output
Programmable output signal.
Offline Programming
Offline Programming
  • ProtoTRAK RX user interface for Windows® PC
VIDEO: Installing ProtoTRAK Offline Software
DXF Converter
DXF Converter
  • Part alignment
  • Feature analysis (circle/arc radius and position)
  • Simple CAD construction/editing tools
  • DXF-output capability
Not available for the ProtoTRAK ELX.
Advanced Features
Advanced Features
  • Thread Repair
  • Gang Tool setup
  • Custom Thread event
  • Tap event
  • Search Edit
The TRAK MTConnect option enables customers to add MTConnect functionality quickly and easily to their machines, so that machine data can be collected using the standard MTConnect protocol.
  • Machine networking through ethernet connection or USB Wi-Fi adapter
  • Collect machine data throughout shop
  • Monitor machine status, receive notifications and analyze data throughout your machines’ history
3rd party software not included.
VIDEO: MTConnect® Option Overview
TRAK RX Series Toolroom Lathes Overview featuring the TRL 1845RX
TRAK TRL 1630RX Lathe featuring the ProtoTRAK RLX
TRAK TRL 30120RX Lathe Overview
8-Station Turret for TRAK Long Travel Lathes
Introducing the TRL 30120RX Gap Bed Lathe | ProtoTRAK RLX
