TRAK TCsi Turning Centers CNC Precision for Modern Manufacturing
Innovative Production Lathes by TRAK Machine Tools
Looking for ProtoTRAK Lathes? We offer toolroom machines in a variety of sizes and configurations. Learn more
TRAK Turning Centers featuring the SINUMERIK ONE CNC
TRAK Machine Tools + Siemens
Siemens has a long history as a world leader in technology and will continue to shape the future of manufacturing. TRAK Machine Tools excels in delivering technology-driven tools that fit the way our customers work.
TRAK TCsi Turning Centers and the SINUMERIK ONE
Strong Rigid Accurate
With features you need for production turning.
Hardened Box Ways on a Solid Casting
Hardened Box Ways on a Solid Casting provide increased rigidity, better damping, and less vibration for all purpose heavy duty cutting.
12-Station Sauter Bolt-On Turret
TC820si Only 12-Station Bolt-On Turret that uses block-style clamping to hold 0.75″ shank tooling. Tools may be bolted to either side of the tool pocket to allow for right or left hand tools. Boring bar toolholders accommodate up to 1.5″ shank diameter.
Live Tool Turret
TC820LTYsi Only Industry standard 12-Station BMT45 Live Tooling Turret ( 4500 RPM) offers ample tool clearance, robust connections, and versatility for various tools, including secondary milling operations, with 1/2 index expandable to 24 tools.
Coolant Through Turret
Coolant Through Turret efficiently dissipates chips and heat during machining. This greatly enhances cutting performance, accuracy, surface finish and tool life.
Manual Tailstock
TC820si Only Manual Tailstock with Hydraulic Quill provides additional support for longer workpieces. Quill stroke of 4.13″ with MT4 taper.
Programmable Tailstock and Quill
TC820LTYsi Only The Hydraulically Clamping Programmable Tailstock & Quill can be automatically positioned along the Z-axis travel and securely clamped in place using built-in subroutines.
Hydraulic 3-Jaw Chuck
4,000 RPM Spindle with 2.56″ Bar Capacity provides high axial thrust and generates minimal heat. It uses four P4 class angular bearings for optimal support and rigidity.
Tool Setter and Probe - TRAK TC820si Turning Center
The TC820si is equipped with a manual Tool Setting Arm and Probe.
The TC820LTYsi features an automatic Tool Setting Arm and Probe, which positions itself to touch off tools using a conversational interface or programmed subroutines, automatically detecting tool wear, breakage, and updating offsets.
Direct Drive Motors - TRAK TC820si Turning Center
Direct Drive on X and Z Axes (and Y axis on TC820LTYsi) provide a rigid connection between the motor and the ballscrew for optimum servo control. This enhances accuracy and eliminates backlash.
Auto Lubrication - TRAK TC820si Turning Center
Automatic Lubrication controlled by the CNC system monitors and distributes oil to the box ways and ballscrews to ensure all critical components are always lubricated with the correct amount of oil.
20 Gallon Coolant System - TRAK TC820si Turning Center
The TC820si is equipped with a 33 gallon tank and pump providing through tool coolant at 30 psi.
The TC820LTYsi has a 50 gallon tank and pump providing through tool coolant at 70 psi.
Chip Conveyor - TRAK TC820si Turning Center
Chip Conveyor features an internal collection and side discharge system with a high rate of material removal. Chip cart is optional.
Siemens Spindle Motor
SIMOTICS M-1PH8 Asynchronous Induction Spindle Motor with 14.75 HP continuous — capable of handling extreme duty cycles and short rise times.
Siemens Axis Motor
High Performance Servo Motors with excellent positioning accuracy.
Other Standard Features:
  • Small footprint and generous 8.66″ maximum turned diameter and 20″ maximum turned length (19.29″ for TC820LTYsi).
  • Heavy Machine Tool Construction provides mass for rigidity and heavy cuts.
  • Solid Casting for vibration absorption and rigidity.
  • Precision Ground Ballscrews
  • Guarding on All Axes to protect the castings, ballscrews and drivetrain systems.
  • 7.88″ Hydraulic 3 Jaw Chuck for A2-6 spindle nose
  • 787 IPM Feedrate on Z-Axis and 590 IPM Feedrate on X-Axis with aggressive acceleration and jerk control for ultra-fast positioning and reduced cycle times.
  • Absolute Position Encoders to eliminate homing and enhance precision.
  • Fine Chip Strainer has a metal screen with 1.7 mm openings to prevent large chips from clogging the coolant pumps.
  • Large Single Front Door with large viewing window for easy access and integration with automation.
  • Y-Axis Travel of 2.75″ TC820LTYsi Only allows for fully synchronized multi-axis interpolation across X, Y, Z and C axis machining.
  • Temperature Compensation uses a preprogrammed algorithm to compensate for the expansion and contraction of the headstock by adjusting the Y0 position.
  • Chip Wash is delivered at 11.6 psi over axis guarding to help with chip evacuation and prevent swarf buildup.
  • Spindle Motor Brake TC820LTYsi Only features holding torque of 220 ft-lbs, clamp force of 630 lbf and a positioning accuracy of 0.01°.
  • Live Tool Stations TC820LTYsi Only features BMT45 tooling with max speed of 4,500 rpm, peak power at 5 HP and max torque of 38 ft-lbs.
SINUMERIK ONE
SINUMERIK ONE
No matter what programming style you know, the SINUMERIK ONE CNC adapts to you.
  • ShopTurn — apply your ProtoTRAK® (or Brand X) conversational skills and start making parts right away.
  • programGUIDE — program in G-code, even with limited experience.
  • G291 ISO Mode (ISO G-code) — your library of programs can be put to work no matter which control they were programmed on.
  • DIN G-code — unleash the world’s most powerful CNC
Models
  • Height of Centers: 41.3″
  • Maximum Turned Length: 20″
  • Number of Tools: 12 Stations (Bolt-on)
TC820LTYsi Turning Center
  • Height of Centers: 47.3″
  • Maximum Turned Length: 19.29″
  • Number of Tools: 12 Live Tool Stations (BMT45)
TRAK TC2 Turning Center - Compact CNC Lathe with ProtoTRAK RLX Control
Introducing the
featuring the ProtoTRAK RLX CNC
Rigid construction and generous capacities make this slant bed lathe ideal for smaller turned parts in lower volume production.
  • Conversational Programming - Easy Setup of Simple Jobs
  • G-Code Compatible - For Easy Upload
  • Hydraulic System Integrated into Machine Body
TRAK TC2 Turning Center featuring the ProtoTRAK RLX CNC
VIDEO: TRAK TC2 Turning Center
Key Hardware Features of the TRAK TC2:
  • ProtoTRAK RLX CNC
  • 2-Axis CNC and DRO
  • 15.6″ LCD screen
  • 4 USB 2.0 ports
  • Built-in LED status light
  • 8-station turret
  • Coolant pump
  • Ethernet port
Advanced Software Features for Easy Programming:
  • Clear, uncluttered interface
  • Prompted data inputs
  • Plain language - no codes
  • Soft keys change with context
  • Windows® operating system
  • Inch/mm selectable
  • G-Code run
  • Canned cycles
  TRAK TC2
Maximum Swing 12″
Maximum Turning Diameter 8″
Maximum Turning Length (Z Axis Travel) 11″
X-Axis Travel 7.5″ (direct drive with brake)
Z-Axis Travel 11.4″ (direct drive)
Oil Pump - Way Lubrication 2 liters
Rapid Speeds 600 IPM on Z Axis
300 IPM on X Axis
Air Requirements 90 PSI
Spindle Nose A2-5
Spindle Through Hole 2.4″ - manual chuck option
2.047″ - hydraulic chuck option
Chuck Diameter 8″ - manual chuck option
6″ - hydraulic chuck option
Drawtube Thread M60 x 2 mm
Spindle Lubrication Grease
Spindle Dia At Front Bearing 100 mm
Number Of Bearings 4
Horsepower 7.5 HP
Number of Speeds or Ranges 1
Spindle Speed Range RPM 50-2500 - low speed, high torque
50-4000 - high speed spindle option
Spindle Motor Brake Dynamic
Turret
Turret Type Bolt on
Number of Tools 8 Stations
Turning Tool Shank Dimensions 0.75″ x 0.75″
Maximum Boring Bar Diameter 1.25″
Turret Index/Clamping Method Servo motor/pneumatic
Power Requirements - Machine
Voltage 208V
480V with transformer option
Amps Full Load Current 42A (208V)
25A (480V)
Phase/Hz 3/60
Net (L x W x H), lbs. 80.4″ x 36.5″ x 75.7″, 3,087 lbs
3,370 lbs with hydraulic chuck option (+283 lbs)
Shipping (L x W x H), lbs. 85″ x 39″ x 87″, 3,200 lbs
3,800 lbs with hydraulic chuck option (+283 lbs)
Coolant
Coolant Pump Motor HP* 1/8 HP
Coolant Reservoir Capacity 15.8 gal
Specifications subject to change.
TRAK TC2 Turning Center Portability
TRAK TC2 Turning Center 8-Station Turret
TRAK TC2 Turning Center Left Three Quarter View
High Speed Spindle
High Speed Spindle
High speed spindle for the TC2 Turning Center.
Maximum of 4,000 RPM compared to standard spindle max. of 2,500 RPM.
Tool Tray
Tool Tray
Tool tray for the TC2 Turning Center.
480V Transformer
480V Transformer
For the TC2 Turning Center.
5C Collet Chuck
5C Collet Chuck
5C collet chuck for the TC2 Turning Center.
The hydraulic chuck option is required.
Hydraulic Chuck
Hydraulic Chuck
6″ diameter hydraulic chuck for the TC2 Turning Center.
This option is required in order to use the 5C collet chuck.
Buck<sup>®</sup> Chuck
8″ diameter manual Buck chuck, A2-5, for the TC2 Turning Center
Manual Chuck
Manual Chuck
8″ diameter manual chuck, A2-5, for the TC2 Turning Center
TRAK<sup>®</sup> USB Memory for Program Storage
TRAK® USB Memory for Program Storage
VIDEO: Seamlessly Store Programs with TRAK® USB Memory
TRAKing<sup>®</sup> for RX Lathes
TRAKing® for RX Lathes
TRAKing of programs during program run, GO TO Dimension in DRO Mode.
VIDEO: TRAKing® Option Overview
CAM File Out Converter
Write, save and then run programs with RX Canned Cycle Events on Legacy ProtoTRAK controls in either .CAM Events or .GCD format.
Auxiliary Output
Auxiliary Output
Programmable output signal.
Offline Programming - ProtoTRAK RX
  • ProtoTRAK RX user interface for Windows® PC
VIDEO: Learn to Install ProtoTRAK Offline Software
DXF Converter
DXF Converter
  • Part alignment
  • Feature analysis (circle/arc radius and position)
  • Simple CAD construction/editing tools
  • DXF-output capability
Advanced Features
Advanced Features
  • Thread Repair
  • Gang Tool setup
  • Custom Thread event
  • Tap event
  • Search Edit
The TRAK MTConnect option enables customers to add MTConnect functionality quickly and easily to their machines, so that machine data can be collected using the standard MTConnect protocol.
  • Machine networking through ethernet connection or USB Wi-Fi adapter
  • Collect machine data throughout shop
  • Monitor machine status, receive notifications and analyze data throughout your machines’ history
3rd party software not included.
VIDEO: MTConnect® Option Overview
TRAK TC820LTYsi Turning Center
TRAK TC820LTYsi Turning Center featuring the SINUMERIK ONE CNC
Specifications for the TRAK TC820LTYsi Turning Center
Key Features of the TRAK TC820LTYsi Turning Center
  • Siemens SINUMERIK ONE CNC
  • 12 Station BMT45 Live Tooling Turret (4,500 RPM) 1/2 Index Expandable to 24 Tools
  • Coolant Through Turret
  • Hydraulically Clamping Programmable Tailstock & Quill
  • 4,000 RPM Spindle with 2.56″ Capacity
  • Hydraulic 3-Jaw Chuck
  • Automatic Tool Setting Arm & Probe
  • Hardened Box Ways
  • Direct Drive on X, Y and Z Axes
  • Solid 8,000 lb Casting
  • Chip Conveyor
Specifications All TCsi Models
  TC820si TC820LTYsi
Height of Centers 41.3″ 47.3″
Maximum Swing 15.75″ 15.75″
Maximum Turned Length (varies with workholding) 20″ 19.29″
Maximum Turned Diameter 8.66″ 8.66″
Rapid Speeds 787 IPM on Z Axis
590 IPM on X Axis
787 IPM on X and Z Axes
590 IPM on Y Axis
X-Axis Travel 6.90″ 8.11″
Y-Axis Travel - 2.75″
Z-Axis Travel 20.8″ 19.69″
Spindle Nose Front A2-6 A2-6
Chuck Diameter 7.88″ 7.88″
Drawtube Thread M74 x 2.0 x 35 mm M74 x 2.0 x 35 mm
Bar Capacity 2.56″ 2.56″
Spindle Bore 3″ 3″
Spindle Front Bearing Diameter (ID) 4.33″ 4.33″
Number of Bearings 4 4
Drive System Belt drive Belt drive
Spindle Speed Range RPM 10 - 4,000 10 - 4,000
Spindle Motor Brake - Yes
Quill Travel 4.13″ 4.72″
Quill Diameter 2.36″ 2.95″
Quill Taper Hole MT4 MT4
Maximum Quill Thrust 691 lbf 1,233 lbf
Spindle
Motor Peak Horsepower (480V) 38 HP 38 HP
Motor Continuous Horsepower (480V) 14.75 HP 14.75 HP
Maximum Torque 100 ft-lbf @ 2,000 RPM 100 ft-lbf @ 2,000 RPM
Spindle Brake Holding Torque - 220 ft-lbs
Spindle Brake Clamp Force - 630 lbf
Spindle Positioning Accuracy - 0.01°
Turret
Number of Tools 12 Stations 12 Live Tool Stations
Up to 24 Stations (Half Index Option)
Turret Type Bolt-On BMT45
Live Tooling Max. Speed - 4,500 RPM
Live Tooling Peak Power (480V) - 5 HP
Live Tooling Max. Torque - 32 Nm
Turning Tool Shank Dimensions 0.75″ x 0.75″ 0.75″ x 0.75″
Maximum Boring Bar Diameter 1.5″ 1.25″
Voltage 480V
208V with transformer option
480V
Amps Full Load Current 38A @ 480V
87A @ 208V
39A @ 480V
90A @ 208V
Phase/Hz 3/60 3/60
Net (L x W x H), lbs. 117″ x 80″ x 65″
8,000 lbs
128″ x 82″ x 79″
9,700 lbs
Shipping (L x W x H), lbs. 120″ x 90″ x 87″
8,500 lbs
138″ x 90″ x 89″
10,700 lbs
Door Opening 22.64″ 25.12″
Coolant Reservoir Capacity 33 gal 50 gal
Coolant Pump Delivery 5.3 GPM @ 30 PSI 5.3 GPM @ 70 PSI
Chip Wash Delivery - 7.9 GPM @ 11.6 PSI
Way Lubrication Capacity 3 liters 3 liters
Way Lubrication Oil Type ISO VG 68 or 20 W ISO VG 68 or 20 W
Hydraulic Oil Capacity 11 gal 11 gal
Hydraulic Pump Type Combination pump vane Combination pump vane
Chip Conveyor Motor 200 Watts 200 Watts
Part Catcher Capacity 1.77″ x 3.94″
3.30 lbs
(Optional)
2.56″ x 4.33″
3.09 lbs
(Optional)
Way Surface Hardness HRC 48~52 HRC 48~52
Specifications subject to change without notice.
Bar Feeder
Bar Feeder
The LNS Quick Load Servo 80 S2 Bar Feeder allows for continuous machining with little or no operator intervention. With quick changeovers from one part run to another and a library of up to 500-part programs this servo driven bar feed will drastically increase productivity.
Equipped with an automatic diameter changing system, centerline and bar loading fingers adjust automatically as the new bar diameter is entered, no manual adjustment is required reducing changeover time to a minimum. The LNS servo motor control technology guarantees accurate bar feedout control with or without turret help and prevents hitting the turret with its soft touch positioning.
Bar Puller
Bar Puller
A low cost device to easily automate your machine. Simply mount on the turret and run bars .125″ to 2.25″ automatically.
Collet Chucks
Collet Chucks
ROYAL QUICK-GRIP™ PULLBACK CNC COLLET CHUCK. Traditional pullback design utilizing Royal QG-65 collets allow for a bar capacity of 2.66” and runout on the closing angle within 0.0002" TIR.
ROYAL QUICK-GRIP™ PULL-TO-A-STOP CNC COLLET CHUCK. Adjustable stop guarantees precise, consistent z-axis part positioning and enables very aggressive cutting. Utilizing Royal QG-65 collets allow for a bar capacity of 2.66” and runout on the closing angle within 0.0002" TIR.
ROYAL LOW-PROFILE 5C PULLBACK CNC COLLET CHUCK. Traditional pullback design provides a simple, low-cost method for utilizing popular 5C collets, guaranteed to run within 0.0002″ TIR. Compact dimensions allow for superior tool clearance and Z-axis travel.
Part Catcher
Part Catcher
The fully programmable TRAK Part Catcher is designed to catch finished parts up to 2.3″ in diameter and 4.25″ in length as they are cut off, facilitating unattended machining. Collected parts are stored in a bin for easy access while the machine operates.
Oil Skimmer
Oil Skimmer
The TRAK Oil Skimmer is operated by a button on the control panel or may be integrated into your program with the use of M code.
High Pressure Coolant
The TRAK high pressure coolant system allows coolant at 220 psi to be delivered directly through the turret and cutting tool efficiently dissipating chips and heat from pockets and holes during machining. This greatly enhances cutting performance, accuracy, surface finish and tool life.
Transformer
Transformer
The TRAK Transformer for the TC820 transforms from S/B 208v to 408v, factory mounted in an enclosure on the top of the machine.
Chip Cart
Chip Cart
Chip cart that fits under the chip conveyor to collect chip remains. Wheels, coolant drain and dumping system for ease of use.
Toolholder Kit
Toolholder Kit
Bolt-On Toolholder Kit; includes 8 wedge clamps for 0.75″ tooling, 3 boring bar holders with 1.25″ bore, 1 slide tool holder and accompanying coolant fittings.
Tooling
Tooling
  • Half index tool holder kit
  • Live tool holders - ER20 and ER25
  • Static tool holder kit
3D Simulation (P25)
3D Simulation (P25)
3D Solid digital twin of your part, faithful in every programmed detail. You can check your program by close inspection of each detail using the touchscreen operation of the 19″ screen of the SINUMERIK ONE.
CNC Memory, 4.6 GB (P12 & P77)
A combination of Siemens options that, together, adds internal memory to the SINUMERIK ONE to bring in and integrate large files (such as CAD and CAM).
DXF Reader (P56)
DXF Reader (P56)
Open DXF files on the SINUMERIK ONE to easily transfer data into your program. Program faster and reduce errors on programming dimensions. Open and use elements of multiple DXF files in the same program. Works within all the programming methods. Easily command specific features from drawing elements. Set your own part reference independent of the drawing origin.
Handwheel Run (M08)
Handwheel Run (M08)
Run the programmed moves by turning the handwheel. You control the feedrate by moving the Manual Pulse Generator on the control panel and the actual programmed path is moved. Adjust the relationship between the handwheel turns and the feedrate with 4 different resolution settings. Seamlessly go between Handwheel Run and fully automatic CNC run. Great for setups and for confidence making that first part!
Execution from External Storage (P75)
Enables the use of an external memory device for running and editing programs. Allows your memory device to function like an expansion of your internal SINUMERIK ONE memory, without any restrictions on programs, subprograms, commands or even transferring to another machine.
Run MyVirtual Machine gives you rich simulations offline. You can program and optimize your jobs while your machine is running a different job.
ARTICLE: Run MyVirtual Machine — The Digital Twin of the Machine Application
Simulation Run During Machining (P22)
3D Solid model graphics real time while running a program. It is a great way to check the progress of your job, especially when you are running a lot of coolant.
ShopTurn (P17)
ShopTurn (P17)
True conversational programming you can do right on the shop floor. Write complete part programs or insert a feature within another program. With guidance from Animated Elements, Tool Tips, Dynamic Graphics, Canned Cycles and Context-Sensitive Help to guide you can create programs with ease. You won’t have to go back to the person who programmed the part to fix or add to your program.
Residual Material Detection (P13)
The SINUMERIK ONE automatically recognizes Rest Machining situations. Simply call up the Residual Machining canned cycle, enter a few simple inputs and the control does the rest.
Match the tool to the operation for fastest machining: large tool for hogging, smaller tool for regions the large tool won’t reach. Multiple Residual Machining cycles in the same feature gives you the flexibility to minimize cycle times.
Access MyMachine OPC UA (P67)
The OPC UA (Unified Architecture) standard is particularly suitable for data exchange across different levels as it is independent from specific operating systems, has secure transfer procedures and better semantic description of the data.
OPC UA not only makes data available, but also provides information about the data (e.g. data types). This enables machine-interpretable access to the data.
SINUMERIK ONE Features & Options
Control Hardware
SINAMICS S120 Combi Drive
A power module with integrated infeed, motor modules for 4 axes (spindle and 3 feed axes). The combi drive has integrated external fans inside the heat sink installed on the back of the drive. It has an integrated brake control function for the motor holding brake and temperature sensor that activates an alarm if the temperature goes above the set threshold.
SINUMERIK ONE PPU 1740-1900
SINUMERIK ONE offers modularity, openness, flexibility and uniform structures for operation programing and visualization. It has integrated drive system SINAMICS S120 and S7-1500 PLC for medium and high-performance application. It offers high flexibility, excellent dynamics response, precision and optimum integration into networks.
VMCsi Control Panel
Machine Control Panel (MCP398C)
The elegant, minimalist MCP-398C has buttons to control the machine operation. Well positioned and clearly marked keys enable you to select X, Y, Z or spindle, select operating modes such as Jog, Auto, Manual Data Automatic (MDA), and activate various motors including augur, coolant, washdown, skimmer, and spindle cooler etc...
TRAK VMCsi Axis Motor
SIMOTICS S-1FK2 Axis Motor
SIMOTICS S-1FK2 are permanent magnet synchronous motors with high overload capability and integrated encoder system for speed and position control. It uses separate power and feedback cables to connect to SINAMICS S120 servo system. The motor has a 22-bit absolute encoder and connects to drive using the advanced DRIVE-CLIQ interface.
TRAK VMCsi Spindle Motor
SIMOTICS M-1PH8 Spindle Motor
The SIMOTICS M-1PH8 is a compact induction asynchronous spindle motor capable of handling extreme duty cycles and short rise times. It is exceptionally precise in terms of speed, torque and positioning. It uses separate power and feedback cables to connect to SINAMICS S120 servo system. The motor has 22-bit incremental encoder, it connects to the drive using the advanced DRIVE-CLIQ interface.
Control Features
General Operation
  • Touchscreen
    • 19” LED Multi-Touch Screen
    • Pan, zoom, pinch, rotate and scan, page up/down, swipe to top/bottom
  • Spindle Functions:
    • Thread cutting with constant or variable pitch
    • Tapping with compensating chuck and rigid tapping
  • Context sensitive help key you press for thorough explanations
  • Tool Tips Pop-up descriptions within programming that automatically appear
  • Tool names make it easy to recognize tools available and assign sister tools
  • Dynamic images change with the selection of the field
  • C-axis motion fully synchronized precision for secondary milling operations with integrated hydraulic brake for lock spindle (TC820LTYsi).
  • Easy In/mm conversions
  • Font colors organize G codes for quick inspection
  • Familiar file management for storing and retrieving programs in a recognizable interface
  • Linux based operating language
  • Open architecture allows you to add apps, refine canned cycles
  • Soft keys intuitively guide you as you work, and a small number of hard keys mapped to machine functions
  • Built-in keyboard and calculator that appears automatically when needed.
  • Multiple channels - 4 channels; 6 axes of control standard (12 axes requires additional hardware)
  • Language support - English, German, Spanish, Chinese and more
Animated Elements
Throughout the operation of the SINUMERIK ONE, you will encounter Animated Elements. These clever mini-videos help you instantly grasp the underlying issue, enabling you to respond quickly and confidently.
Contour Editor
This powerful tool works within the all the programming methods of the SINUMERIK ONE. Use graphical elements to create even complex shapes. Automatically calculates intersections and points of tangency.
Also use Contour Editor to work with elements in DXF files. Open the drawing data within the Contour Editor, then use define tool path and even edit the geometry.
Programming Operation
  • Canned cycles make programming fill-in-the-blanks easy
  • In-process error detection explained in plain language
  • Math calculations in data input fields
  • Easy transition between programming, manual and automatic CNC operation screens
  • Selectable views – wireframe or model
  • Program summary - easily inspect even your largest programs
  • Easy program restart from stopping point
  • Easy building of programs – Combine G-code and conversational programming in the same program
  • Run time clock
  • Show G-code during program run
  • Soft limits for collision avoidance
  • Fast block processing time
  • Selectable programming for the style that fits your job and your shop - ISO, DIN, ShopTurn, programGUIDE
  • Automatic staging of next tool in ShopTurn conversational
  • Macro programming - Calling and running, master programs and subprograms
  • Residual machining detects and machines material left over from the tool and part geometry.
  • Hydraulic tailstock quill with adjustable thrust pressure can be programmed throughout the travel vial M-codes or controlled via buttons on the Manual Control Panel.
Powerful Program Simulations
  • True representations of part and tool geometry.
  • 3D graphics with zoom and rotation of viewing angle. (O)
  • Controls for program speed, single block operation and stop/start.
  • Calculations for machining time.
  • Run simulations of different programs as a job is being run.
Use simulations:
  • As you program to verify the program accuracy.
  • Before you run to calculate cycle times and check for crashes.
  • During run so you can see the program progress when coolant keeps you from seeing the actual part and tool (O)
Tool Probing
Probing is integrated into the Jog Mode so you can set up tools easily and quickly.
Powerful DRO (manual mode) Routines
Part set up manual or with a probe.
Tool Setups
Setting tools is simple due to the icons and Animated Elements that guide your selections. You define number of flutes, tip angle, cutting edges, holder angle, tool type and even tool life. A Magazine view shows which tools are in the magazine.
Tool, Spindle, M-Code (TSM)
A single key gives you access to features such as loading tools, activating a work coordinate or turning on a spindle. Unlike the cumbersome MDI of other production controls, all operations are commanded by answering conversational prompts. This greatly simplifies set up.
Return from Jog (REPOS)
While running programs, the SINUMERIK ONE can halt the current operation and the tool tip can be jogged away from the part surface, allowing you to inspect the tool or part. the REPOS feature let’s you return to the part where the machining was stopped.
Mid-program Start
Stuff happens, power outages, tool breakage, unanticipated moves. The SINUMERIK ONE gives you unprecedented ability to get back to where you were in the part with a high degree of confidence and with minimal work. Powerful Block search and Interrupt point combine to get you started exactly where you left off or at a point before…just to make sure. This powerful routine even enables a tool retract/recover that is able to define the exact location and proper speed to recover a tap stranded by an unplanned interruption.
Control Options
DXF Reader (P56) (O)
Execution from External Memory (P75) (O)
Handwheel Run (M08) (O)
Residual Material - Turning - SINUMERIK ONE
Residual Material Detection (P13) (O)
The SINUMERIK ONE automatically recognizes Rest Machining situations, simply call up the Residual Machining canned cycle, enter a few simple inputs and the control does the rest.
ShopTurn (P17) (O)
Simultaneous 3D Run (P22) (O)
24 Station Half Indexing (TC820LTYsi) (O)
Increase the number of available programable tool stations to 24 with half indexing turret positions. Have better flexibility and capacity with tool setups while still maintaining all 12 stations that accept live tools.
Downloads
[.tcsi-resources]
Models
TRAK TC820si Turning Center featuring the SINUMERIK ONE CNC
Specifications for the TRAK TC820si Turning Center
Key Features of the TRAK TC820si Turning Center
  • 12 Station Bolt-On Turret
  • Manual Tailstock with Hydraulic Quill
  • Tool Setting Arm & Probe
  • Hardened Box Ways
  • Direct Drive on X and Z Axes
  • Chip Conveyor
  TC820si TC820LTYsi
590 IPM on X Axis
590 IPM on Y Axis
Spindle Bore 3″ 3″
Spindle
Turret
Voltage 480V
480V
87A @ 208V
39A @ 480V
90A @ 208V
Phase/Hz 3/60 3/60
8,000 lbs
128″ x 82″ x 79″
9,700 lbs
8,500 lbs
138″ x 90″ x 89″
10,700 lbs
3.30 lbs
(Optional)
2.56″ x 4.33″
3.09 lbs
(Optional)
Bar Feeder
Bar Feeder
Bar Puller
Bar Puller
Collet Chucks
Collet Chucks
Part Catcher
Part Catcher
Oil Skimmer
Oil Skimmer
Transformer
Transformer
Chip Cart
Chip Cart
Toolholder Kit
Toolholder Kit
3D Simulation (P25)
3D Simulation (P25)
DXF Reader (P56)
DXF Reader (P56)
Handwheel Run (M08)
Handwheel Run (M08)
ShopTurn (P17)
ShopTurn (P17)
Control Hardware
VMCsi Control Panel
Control Features
General Operation
  • Touchscreen
Animated Elements
Contour Editor
  • Run time clock
Use simulations:
Tool Probing
Tool Setups
Mid-program Start
Control Options
ShopTurn (P17) (O)
Downloads
[.tcsi-resources]
Models
TRAK TCsi Specifications
TC820si
TC820LTYsi
590 IPM on X Axis
590 IPM on Y Axis
Spindle Bore 3″ 3″
Spindle
Turret
Voltage 480V
480V
87A @ 208V
39A @ 480V
90A @ 208V
Phase/Hz 3/60 3/60
8,000 lbs
128″ x 82″ x 79″
9,700 lbs
8,500 lbs
138″ x 90″ x 89″
10,700 lbs
3.30 lbs
(Optional)
2.56″ x 4.33″
3.09 lbs
(Optional)
Models
