ProtoTRAK RLX CNC - Programming Powerful and always easy
Programming the ProtoTRAK RLX is simply a matter of choosing the geometry from among the canned cycles and then answering the prompts one by one. Everything is in plain language with no codes for you to memorize.
Events
Programming is a simple process of selecting the Event and then describing the geometry from print data. You may program prints or just write simple programs for single operations... it's that easy.
Tap the one you want...
ProtoTRAK RLX CNC Event Updates
...and fill in the prompts
ProtoTRAK RLX CNC Event Prompts
ProtoTRAK RLX CNC Canned Routines
Canned Routines
There are a dozen canned routines that make it easy to program even complex shapes right on the shop floor.
ProtoTRAK RMX CNC Options
Verify Simulation
It is easy to catch mistakes with the powerful graphics of the ProtoTRAK RLX. Optional Verify will give you an animated simulation, allowing you to check your tool set ups and reference positions as well as your programmed toolpaths.
ProtoTRAK RMX CNC Canned Cycles
Cycles
With most CNCs you must define all of the toolpath for you part. But with the powerful cycle event of the ProtoTRAK RLX, you simply define your part geometry and the dimensions of your stock. The toolpath is generated for you automatically.
