Table size | 27.56″ x 15.75″ | 35.43″ x 19.69″ | 44.09″ x 19.69″ | 51.18″ x 23.62″ | 62.99″ x 23.62″ |
Travel (X, Y, Z axis) with soft limits | 20″ x 16″ x 20″ | 30″ x 20″ x 20″ | 40.75″ x 20″ x 20″ | 50″ x 27″ x 25″ | 60″ x 27″ x 25″ |
Rapid traverse X, Y, Z | 400 IPM in Toolroom Ops 1,000 IPM in Production Ops |
T-slots (number x width x pitch) | 3 x .709″ x 3.937″ | 5 x .709″ x 3.937″ | 5 x .709″ x 3.937″ | 5 x .709″ x 3.937″ | 5 x .709″ x 3.937″ |
Spindle taper | 40 Taper | 40 Taper | 40 Taper | 40 Taper | 40 Taper |
Spindle speed range | 50 - 8,000 RPM 50 - 12,000 RPM (optional) |
Spindle nose diameter | 3″ | 3″ | 3″ | 3.75″ | 3.75″ |
Tool clamping force (90 psi) | 1,500 lbs | 1,500 lbs | 1,500 lbs | 2,200 lbs | 2,200 lbs |
Tool holder type | CAT 40 or BT 40 | CAT 40 or BT 40 | CAT 40 or BT 40 | CAT 40 or BT 40 | CAT 40 or BT 40 |
ATC tool capacity | 16 | 16 | 16 | 16 | 16 |
Maximum tool weight (incl. holder) | 15 lbs | 15 lbs | 15 lbs | 15 lbs | 15 lbs |
Maximum tool diameter | 3.14″ | 3.14″ | 3.14″ | 3.14″ | 3.14″ |
Carousel speed | .8 sec from station to station | .8 sec from station to station | .8 sec from station to station | .8 sec from station to station | .8 sec from station to station |
Tool selection system | Bi-directional/shortest path | Bi-directional/shortest path | Bi-directional/shortest path | Bi-directional/shortest path | Bi-directional/shortest path |
Spindle motor HP - peak | 15 HP | 15 HP | 15 HP | 22.5 HP | 22.5 HP |
Spindle motor HP - continuous | 10 HP | 10 HP | 10 HP | 15 HP | 15 HP |
Power requirements Standard (208V) 8K Spindle |
208V (200-240V is acceptable), 3P, 68A (Current can be as high as 87 amps with all options ordered - CTS (+14A), 4th axis (+5A)) |
208V (200-240V is acceptable), 3P, 93A (Current can be as high as 112 amps with all options ordered - CTS (+14A), 4th axis (+5A)) |
Power requirements Standard (208V) 12K Spindle |
208V (200-240V is acceptable), 3P, 69A (Current can be as high as 88 amps with all options ordered - CTS (+14A), 4th axis (+5A); includes cooler current) |
208V (200-240V is acceptable), 3P, 96A (Current can be as high as 115 amps with all options ordered - CTS (+14A), 4th axis (+5A); includes chiller current) |
Power requirements Optional (480V) 8K Spindle |
480V with transformer option (432-528V is acceptable), 3P, 46A 46 amps based nominal rated current of transformer |
480V with transformer option (432-528V is acceptable), 3P, 48A (Current can be as high as 57 amps with all options ordered - CTS (+6A), 4th axis (+3A)) |
Power requirements Optional (480V) 12K Spindle |
480V with transformer option (432-528V is acceptable), 3P, 49A (Current can be as high as 58 amps with all options ordered - CTS (+6A), 4th axis (+3A); includes chiller current) |
Maximum weight of workpiece | 880 lbs | 1,320 lbs | 1,760 lbs | 2,200 lbs | 2,640 lbs |
Height of table from bottom of bed*** | 38″ | 38″ | 38″ | 38.37″ | 38.37″ |
Min. spindle nose to table distance **** | 3.5″ | 3.5″ | 3.5″ | 2.25″ | 2.25″ |
Max. spindle nose to table distance **** | 23.50″ | 23.50″ | 23.50″ | 28.75″ | 28.75″ |
Distance of tool carousel to table | 18″ | 17.50″ | 17.50″ | 21.50″ | 21.50″ |
Spindle center to spindle head casting face | 16.50″ | 18.25″ | 18.25″ | 27.56″ | 27.56″ |
Min. machine height *** | 90″ | 90″ | 90″ | 105″ | 105″ |
Max. machine height (head all the way up) *** | 106.5″ | 106.5″ | 106.5″ | 120.5″ | 120.5″ |
Overall width of machine with side doors open, auger chute and chip container in place | 159″ | 167.25″ | 174.50″ | 206.27″ | 224.13″ |
Overall length of machine with electrical cabinet fully open 180° | 146″ | 152″ | 152″ | 156.22″ | 156.22″ |
Footprint of machine with coolant tank & auger in place and pendant rotated 90° (width x length) | 92″ x 129.25″ | 97″ x 135″ | 111″ x 135″ | 133.86″ x 144.76″ | 157.48″ x 144.76″ |
Weight net / shipping (lbs) | 7,260 / 7,610 | 8,360 / 8,710 | 9,900 / 10,250 | 14,300 / 14,800 | 16,500 / 17,000 |
Coolant capacity | 56 gal | 56 gal | 56 gal | 71 gal | 71 gal |
Coolant pump and wash power | 750 Watt | 750 Watt | 750 Watt | 750 Watt | 750 Watt |
Air - CFM (at 90 psi), SCFM | 2.5 CFM, 18 SCFM | 2.5 CFM, 18 SCFM | 2.5 CFM, 18 SCFM | 3.0 CFM, 25 SCFM | 3.0 CFM, 25 SCFM |
Air quality | Air dried/water separator upstream of TMC | Air dried/water separator upstream of TMC | Air dried/water separator upstream of TMC | Air dried/water separator upstream of TMC | Air dried/water separator upstream of TMC |
Lubrication pump capacity | 2 liter | 2 liter | 2 liter | 2 liter | 2 liter |
