TRAK VMCsi Specifications
TRAK VMC7si Vertical Machining Center
VMC7si
TRAK VMC10si Vertical Machining Center
VMC10si
TRAK VMC12si Vertical Machining Center
VMC12si
TRAK VMC14si Vertical Machining Center
VMC14si
Machine Specs
Table size 35.43″ x 19.69″ 44.09″ x 19.69″ 51.18″ x 23.62″ 62.99″ x 23.62″
Travel (X, Y, Z axis) 30″ x 20″ x 20″ 40″ x 20″ x 20″ 50″ x 27.5″ x 25″ 60″ x 27.5″ x 25″
Travel (X, Y, Z axis) with soft limits 30.16″ x 20.24″ x 20.24″ 40.35″ x 20.24″ x 20.24″ 50.07″ x 27.70″ x 25.06″ 60.07″ x 27.70″ x 25.06″
Rapid traverse X, Y, Z 1,000 IPM 1,000 IPM 1,000 IPM 1,000 IPM
Cutting max. speed X, Y, Z 1,000 IPM 1,000 IPM 1,000 IPM 1,000 IPM
T-slots (number x width x pitch) 5 x .709″ x 3.937″ 5 x .709″ x 3.937″ 5 x .709″ x 4.921″ 5 x .709″ x 4.921″
Maximum weight of workpiece 1,518 lbs 2,024 lbs 2,530 lbs 3,036 lbs
Height of table from bottom of floor*** 38″ 38″ 42″ 42″
Min. spindle nose to table distance **** 3.5″ 3.5″ 3″ 2.5″
Max. spindle nose to table distance **** 23.50″ 23.50″ 28″ 27.25″
Distance of ATC arm to table 20″ 20″ 25.75″ 25″
Min. machine height *** 93.5″ 93.5″ 106″ 106″
Max. machine height (head all the way up) *** 108″ 108″ 119.25″ 119.25″
Overall width of machine with side doors open and chip conveyor (no chip bin) 177″ 177″ 202.63″ 226.25″
Overall length of machine with electrical cabinet fully open 180° 150.25″ 150.25″ 156.63″ 156.63″
Footprint of machine with chip conveyor & coolant tank in place. Pendant not rotated 90° (width x length) 144″ x 112″ 144″ x 112″ 168.25″ x 126.50″ 180″ x 126.50″
Weight net / shipping 8,360 lbs / 8,710 lbs 9,900 lbs / 10,250 lbs 15,400 lbs / 15,900 lbs 17,600 lbs / 18,100 lbs
Spindle Specs
Spindle taper 40 Taper 40 Taper 40 Taper 40 Taper
Spindle speed range 10 - 12,000 RPM 10 - 12,000 RPM 10 - 12,000 RPM 10 - 12,000 RPM
Spindle nose diameter 3″ 3″ 3.75″ 3.75″
Tool clamping force (90 psi) 1,500 lbs 1,500 lbs 2,200 lbs 2,200 lbs
Tool holder type CAT 40 standard
BT 40 optional (must change ATC arm)
CAT 40 standard
CAT 40 standard
CAT 40 standard
ATC tool capacity 24 (30 optional) 24 (30 optional) 30 (40 optional) 30 (40 optional)
Maximum tool weight (incl. holder) 17.6 lbs 17.6 lbs 17.6 lbs 17.6 lbs
Maximum tool diameter 3.07″ 3.07″ 3.07″ 3.07″
ATC arm tool change time 2.5 seconds 2.5 seconds 2.5 seconds 2.5 seconds
Spindle motor HP - peak 41.5 HP 41.5 HP 67 HP 67 HP
Spindle motor HP - continuous (480V) 20.1 HP 20.1 HP 26.8 HP 26.8 HP
Spindle center to spindle head casting face 18.25″ 18.25″ 26.75″ 26.75″
Spindle cooler oil capacity ~1 gallon ~1 gallon ~4.25 gallon ~4.25 gallon
Power Requirements
Power requirements - standard 480V (456-504V is acceptable), 3P, 41A 480V (456-504V is acceptable), 3P, 41A 480V (456-504V is acceptable), 3P, 69A 480V (456-504V is acceptable), 3P, 69A
Power requirements - optional 208V with transformer option (200-240V is acceptable), 3P, 94A 208V with transformer option (200-240V is acceptable), 3P, 94A n/a n/a
Coolant System
Tank capacity 60 gallons 60 gallons 78 gallons 78 gallons
Pressure and volume 8.7 gpm @ 42 psi 8.7 gpm @ 42 psi 8.7 gpm @ 42 psi 8.7 gpm @ 42 psi
Pump and wash power 750 watts 750 watts 750 watts 750 watts
Coolant wash pump 750 watts 750 watts 1,290 watts 1,290 watts
CTS pump (Coolant Through Spindle) 3 KW / 4 HP 3 KW / 4 HP 3 KW / 4 HP 3 KW / 4 HP
CTS pressure 319 psi 319 psi 319 psi 319 psi
Air Requirements
Air - CFM, SCFM (at 90 PSI) 2.5 CFM, 18 SCFM 2.5 CFM, 18 SCFM 2.5 CFM, 18 SCFM 2.5 CFM, 18 SCFM
Air quality Air dried/water separator upstream of VMC Air dried/water separator upstream of VMC Air dried/water separator upstream of VMC Air dried/water separator upstream of VMC
Lubrication Requirements
Lubrication pump capacity 2 liters 2 liters 2 liters 2 liters
Lube Oil Type ISO 32 or 10 W ISO 32 or 10 W ISO 32 or 10 W ISO 32 or 10 W
Specifications subject to change. ** Must remove ATC motors and all sheet metal attached to top of electrical cabinet. The cable way for Z axis also needs to be removed. The lifting point on the electrical cabinet is now the highest point. *** Height changes slightly based on how machine is leveled on leveling screws. **** Can vary slightly due to soft limit settings.
